engine acting strange????
  • AUDIS2avant
    • Jan 2009
    • 670
    • Country: Denmark
    Am having a few probs with the car.
    found out yesterday that the piping to the dv wasent connected and hose to maf-turbo had fallen off, so after fitting them back on (and making sure they dont come off again) the car sets out when coming on full boost????????
    It´s also having problems on standstill but not sure this has anything to do with anything tho.
    What you guys think?
    Have taken the batteri off for a few hours to reset the ecu, but will it be enough?
  • AUDIS2avant
    • Jan 2009
    • 670
    • Country: Denmark
    Just done some more testing, all pipes are ok, all vacum pipes are ok also.
    I can Cheat it a little bit by controling the boost with the accelerator, but it keep coming when i just flor it?????
    Also when coming in to a letf or right turn and pressing the clutch, the engine goes out some times, mystery getting bigger now
    • AUDIS2avant
      • Jan 2009
      • 670
      • Country: Denmark
      Today i was out again after trying to find the error, and it also does this under light load, say 0,2bar @ 2200rpm and again 2400rpm, can this be a MAF error or maybe the fuel pump / filter?
      • david
        • Oct 2008
        • 1268
        engine
        Hi mate,i think this is a common problem with s2,s.I think you should concerntrate on the MAF.
        [SIGPIC][SIGPIC]/SIGPIC]92 3B pearl white=gone back home to Germany,probably in bits and pieces
        RS2 VOLCANO BLACK] soon to be broken to bits
        • AUDIS2avant
          • Jan 2009
          • 670
          • Country: Denmark
          david : thanx m8, have already ordered a new maf, just in case.
          Hope to resolve it this way.
          • AUDIS2avant
            • Jan 2009
            • 670
            • Country: Denmark
            just wanted to say i changed the MAF-sensor today, and all is fine again
            ****ing thing is flying now
              MAF sensor is the most critical device on the S2 engine... Just catching up with this post now. Good man !
              • Colesy
                • Feb 2009
                • 2980
                Maf
                Think I might have a similar problem!
                Having trouble ideling usually when the car is fairly warm - it keeps on wanting to stall. It's a fairly intermittent problem but definitely seems to becoming more frequent. So I'm thinking after reading this post and a few others that a MAF sensor would be a good place to start?
                If that's a good idea can anyone recommend where to get a MAF sensor from? Also is it an easy enough job for an amateur?!
                Sorry for the thread hijack!
                • Colesy
                  • Feb 2009
                  • 2980
                  Can anyone help with this?
                  • AUDIS2avant
                    • Jan 2009
                    • 670
                    • Country: Denmark
                    Will : give quattro corner a call, and yes, it´s a 10min job WERY easy to do.
                    And btw, mine had thoose problems too, idle trubble but mostly on warm engine
                    • Jonas_R
                      • 3780
                      • Country: Denmark
                      Did you get the fault codes read out?
                      Sleeper S2 Avant +450
                      A6 Avant 2.7t Stage 3
                      Audi S2 Coupe RS2'ed
