Which OEM look Boost Gauge?
I would go for the VDO gauge as posted earlier, looks the most OEM in my opinion.
maybe someone has found the best price for this VDO OEM lookalike turbo pressure gauge..
http://www.hoffmann-speedster.com/dt...d/VDOINSTR.asp
why dont you buy it from the source...?
http://www.audis2fast.de/ then pick teile and 3d one from top!
he can sell and send it to you with fittings. Maybe a bit more expensive than the rest,but hey, IT MATCHES!!!
Has anybody seen electrical fuel pressure gauge like this?Comment
problem is that this turbo gauge does not show vacuum, which is rather annoying.Comment
I have certainly seen them before but the one which matches the aux gauges for needle deflection and looks (pictured above) is only 0-2 bar. Most people want at least 2.5 bar and also prefer the -0.5 bar for vacuum.
The black one in the Hoffman link above (2nd from last gauge) is how the one I ran 5 GB's for started out in life. It was then dismantled, had the face changed and was then recalibrated - all by Gerd.
These are still available directly from Gerd. If you mention me (Simon - the one who bought over 40 from him) you may get a small discount as others did this whilst I was running the GB's to take advantage of the GB price.
Cheers n
Subtle mods here and there
2011 A5 3.0 TDi - Lava Grey
With every option available
(except a towball)Comment
currently: 1987 944 NA 5spd, 250 lb hyper coils, 27 mm t bars, Koni, 968 m030 bars, full delrin, Audi I5 20VT, VEMS, Tilton, EFI Express, Seimens, Race Technologies
see the AAN/944 swap at Nina's 20VTComment
They are reasonably priced too.
