pistons
  • Habib
    • 316
    • Home: United Kingdom Current: Italy
    pistons
    does anybody know what pistons and rods are the best
  • Mark Halligan
    • 2001
    Well I'd trade my right nut for a set of Carrillos or Pauter rods right now, cos I sure aint got the money for them...yet.
    I've read elsewhere that the standard pistons are good for 500-600 bhp , especially if they are ceramic coated, but maybe someone else here knows better.
    Mark.
    Mark - Modded
    • JariP
      • 192
      Atleast MTM claim that the original pistons are good for 600bhp, don't know about the ceramic coating.
      I recommend too that you read through the Kruemmer archives, there are a lot of interesting information about high power I5 engines.
      • Albert
        • 1500
        • Country: Poland
        If You will not run Nitro you should use Mhale
        or Omega Pistons.
        If Nitro + high boost than
        Roos pistons
        ROSS RACING PISTONSCustom and off the shelf forged pistons, trusted by some of the fastest racers in the world.ROSS RACING PISTONSCustom and off the shelf forged pistons, trusted by some of the fastest racers in the world. CUSTOM & OFF THE SHELF FORGED
        or JE
        http://www.jepistons.com
        But remember You need roods to witch is a bigger problem in 2.2T.
        carrillo www.carrilloind.com
        crower www.crower.com
        cunningham www.cunninghamrods.com
        eagle www.jsbengineering.com
        oliver www.oliver-rods.com
        pauter www.pauter.com
        race engineering www.raceeng.com
        I would go with carrillo or pauter. I know that there are ones made in Sweden but i forgot the name.
        AKmotorsport.net - Manufacturing Motorsport parts that do the job. | Audi S2 on Facebook | Best way of reaching me is sending email to albert@akmotorsport.net
        • Mihnea
          • 1288
          @Albert: you surely mean Autoverdi but they are expensive.
          @All: For an engine under 450 BHP/550Nm I'd stick with standard rods/pistons, afterwards stock pistons are still good but will need machining to drop compression a bit. For rods I know for sure that the stock ones as "just a little weak" at 600 Nm (meaning they don't always fail) so I'll try some rods that are cheap but a little more than "just a little" stronger than stock rods, which should be fine. For what it's worth, Lehmann uses stock rods for 700 HP 20vt engines so he can't be that stupid.... but where MTM will use 2 Bar and 20 degree of advance, Lehmann will only use 1.3 Bar and 45 degree of advance so that may surely help
          www.MRCTuning.com
          info@MRCTuning.com
          Workshop Directions
