Im trying to datalog as much info as possible from the motronic whilst changing to VEMS in a short while. I was amazed to realise that on full throttle and with about 2bar to 1.8bar of boost im getting somewhat of 20degrees of advance.!!
I dont seem to have any knock,engine is running perfectly,and IAT was 27-30C on that run with no water injection in operation.
From the little knowledge i have,i know that this is rather aggressive.To whoever knows this however here is a question:
Is the ignition log from VAGCOM the actual advance you are seeing derived from any maps that could adjust it?Is that the final figure that i am getting, or is it lowered somewhere within the map to compensate,and im just looking at a false number?
thanks
vasilis
thanks
vasilis
