RS2 Upgrade problems!
  • stevieyid
    • Apr 2005
    • 2251
    I now have my RS2 items fitted and the homefry RS2 chip by Paul. I just fitted a new wgfv and i borrowed my brothers BOV as my other S3 DV had a split in it. I just went out and opened the old girl up for the first time on her new set up. It boosted off the scale on my boost gauge (which only goes up to 20 psi new one on the way). When i cam to a junction i stopped and opened her up in first gear, the car took off and i thought this is more like it Then i changed in to second gave it WOT and the car just coughed and spluttered and hardly went anywhere I span the car around staright away and had to nurse it home coughing and spluttering
    Any ideas? Have i done something wrong in fitting the DV and BOV?
    3'' Longlife Exhaust, Koni Adjustables, H&R Springs, Full RS2 Setup with Mr Nugents RS2 Chips (just need the RS2 Airbox)
  • DJones
    • Jun 2005
    • 2020
    If 1st gear initially went well i would check that you have not blown any pipes off.
    • stevieyid
      • Apr 2005
      • 2251
      Yeah fist gear went brilliantly but when i changed gear it just coughed and spluttered. 1.5Bar is 21psi is that right?
      • s2martyn
        Banned
        • Apr 2008
        • 408
        1.5 bar is 21 psi..which maf did you use?rs2?does the motor tickover ok and rev ok at standstill?
        • stevieyid
          • Apr 2005
          • 2251
          no its standard s2 airbox and maf at the moment. The car does try to die on tick over and is a bit rough but then after a while seems to settly
          • s2martyn
            Banned
            • Apr 2008
            • 408
            try disconecting battery or use vagcom to erase fault codes then try it again..sounds like overboost protection
            • stevieyid
              • Apr 2005
              • 2251
              when ihave had overboost protection before it has not affected normal driving really. just wont let you boost abouve 5 psi. This is affecting normal driving so much so i had to nurse it home in first gear doing about 15mph. Just started it up and the idle is a bit rough and when you rev it the revs drop anbd the car nearly stalls. Do u think there is a boost leak?
              • Fat Audi 80
                • 10547
                Massive intake leak with a pipe blown off is my bet...
                The Perfectionist
                • Jas11n
                  • 5067
                  Blown off pipe ! ! Probably turbo to intercooler.
                  2001 Avus Silver B5 RS4.
                  1995 S2 Coupe - sold (sniff)
                  • stevieyid
                    • Apr 2005
                    • 2251
                    Ok thanks ill check it. I know the o ring needs replacing aelred advised me of that. But i thought the mark h mod would would be ok. Ill check it
                      Pipe off the bottom off DV is my bet, done that a number of times. I've noticved that on a new ECU the boost goes mad once and then is OK. Check the pipes and then go again
                      • stevieyid
                        • Apr 2005
                        • 2251
                        Thanks for the help, ill check it in a minute
                        • stevieyid
                          • Apr 2005
                          • 2251
                          Top marks to that man. Just checked it and sure enough the hose had blown off the bottom of the bov. New hose clip tightened up and she is like a rocket!
                            I love threads like this... Was aware of the DV issue earlier, advised Stevie, then went out to play in the sunshine. Back home to find it all fixed. Cool
                            Stevie is running my RS2 N-Stream with the 2.5bar MAP.
                            An RS2 airbox will help that setup breath better - or modify your ABY one - Rusty style.
                            • stevieyid
                              • Apr 2005
                              • 2251
                              Seems like im going to be researching Rusty's mod then. The car rockets now. First gear is untrue!
