when I aim to get to about five thousand revs in any gear, I get to three and a half and you would think I was turning a kill switch on off on off on off ! it chucks you forward, throws you back, chucks you forward, throws you back, its like a buckin bronco! if anyone can help me PLEASE DO!!!!!!!!!! cheers
It wasn't a boost leak when mine did that, it was a dodgy connection on the mass air flow sensor .
I just unplugged it and plugged it back in a few times gave it a wiggle and all was fine .
That was 8000 miles ago and hasn't done it since.
Worth a try anyway as it takes no time at all to do , just remember to disconnect the battery to reset the ECU as well .
Seriously though - nuthin from Haynes of much use to S2 specific things - but there is one for the 20V non turbo Coupe - useful for brakes, running gear, bodywork & trim.
You can find most of what you need on here, www.s2central.net and www.s2-audi.co.uk. There's alos SJM autotechnic and a few OOOO manuals that can be found if you look about the place.
