you should be alright.... its just that with the -6AN fpr, that will be the point of the restriction, the o-ring -6AN fitting. you can run a -16AN line to it, but it will still run what can go thru the -6AN adapter fitting.
i am going to run mine ( same Fuelab -6AN FPR ) with twin 044's feeding the rail with -10AN.... i run 1600cc injectors for that chassis, with E85. i think the -6AN return should work fine.
my rabbit runs the A-1000 via -8AN all the way from cell to rail. then -6AN return. i run it 4BAR static, boost-referenced ( +1 psi fuel for each +1 psi boost) @ 36psi in 4th. and the return seems to work good.
But, the tank diameter can be the same as the stock pumps basket, so you can get it inside the tank. Only the fastenings/mountings is the difficult part.
