how the dikkens do you remove the exhuast cam?!
  • avants2turbo
    • Feb 2008
    • 1287
    what am i doing wrong!?
    have removed the bearing caps, undone the cam position sensor, but cant remove it, as theres no way of extracting it from behind the cam pulley?
    getting really annoyed with the bloody thing!
  • jade
    • Jan 2005
    • 1811
    Not sure what you mean (Remove the cam pulley no) if you dont have a cam pulley locking tool Just stick a screw driver in to block it, the key on the cam pulley is fragile so proceed with care. it only torqued to 60nm
    RS 2 580HP
    • mcandmar
      • Apr 2004
      • 5118
      You need to pull the cam pulley off, best method is to grab hold of the cam with a plumbers wrench and undo the nut with the other hand. You will need to put the bearing caps and timing belt back on to hold eveything in place.
      91CQ20v - Gone to a new home
      93UR-S4 - The Magic Carpet
      94S2Bus - The Emerald Express
