Comp turbo leaking oil in to hotside
Really then explain how you and countless others are flocking away from the tried and tested or hammering said tuner with questions over the turbo?
My comments were on the product your was an attempt at a personal attack big difference indeed.Comment
a nice big oil return helps. as does vertical entry and exit
**** happens. there are many a good product out there and all have return rates.
id say that both comp and garrett do good turbos. or whoever else. just because 2 people have had issues doesn't make them ****.
i myself prefer the precision turbos. never had an issue so.... doesn't make them any better or indeed worse than the rest.
we are talking very similar items here and i have read about many an issue where centre sections are not at correct angle or have adequate in and out flow or restrictor issues thats hurting seals.
get it flowing in well and just as importantly out well and turbos are in general mega-reliable.Comment
The lead is quite direct the angle looks gooda nice big oil return helps. as does vertical entry and exit
If i use larger hose and fittings. The exit of the turbo is 13mm & the entry in to the sump is 13mm the only thing i will have is bigger hose between these points, not sure if that will help the flow much, It might help a littleRS 2 580HPComment
