right im getting to my whits end with this problem..
when driving i see max boost of around 1 bar but it soon tails off to 0.4-0.5 bar and feels like the cars holding back. if u take your foot off then plant it again back to 1.0 bar car pulls really well then tails back off again to 0.4-0.5 bar.
so far i've.
fitted new reserc valve
swopped N75 (altho its a new on fitted)
car has had new turbo, wastegate, head rebuild, new ecu (all this just befor i had it)
have boot leak tested car
fitted mark H mod after found that leaking
replaced all vacume hoses
set mechanical boost at 0.4bar after finding it had been set much higher causing boost cut.
checked wiring to n75 all ok
so the burning question is now what the hell do i check next as i feel its beating me and i love the car just not this
issue..
only thing i cant seem to get an answer on is why when checking for leaks the air bleeds off into the wastegate through the vacume and i dont know if this is normal?
any help would be awsome people..
Matt
so far i've.
issue..only thing i cant seem to get an answer on is why when checking for leaks the air bleeds off into the wastegate through the vacume and i dont know if this is normal?
Matt
... normally though, if its a leak you'll get the "\MAF Cutout" effect and the car will lurch badly.
