Sport Quattro Turbos & Exhaust Manifolds
  • martinjs
    • 3205
    i see that these guys have removed the aux rad on their cars, so is it really not needed?
    • porkkis
      • 1994
      It's ok to remove it as long as air flows freely to the main radiator and the car is not operated in warm (I mean Warm) conditions. In UK there should be no problem.
      And well... you can always try, can't you? Block the aux hoses and remove the aux rad and go for a spin.
      • Dr H
        • 1175
        The cooling fan on a standard S2 cuts in quite quickly in traffic as the engine generates a load of heat, even in cold weather. I'd be surprised is removing the aux radiator was possible if you used the car in 'every day' situations
        Just my opinion (which could be totally wrong )
        Leigh
        Ex 1994 Avant - now driving a Lotus 340r
