I'm I right in assuming that the fuel map and the FPR is the only thing controlling fuel at WOT?
My car seems to be running rather rich at the moment, and it where not before. I'm seeing AFR values as low as 10.2 I think.
Nothing has changed so I'm thinking something has gone wrong with the fuel pressure.
I'm getting some equipment, so I can check what it is, but running 7A FPR so I should see 4 bar absolute at fuel rail?
it is too rich mixture true??
i had 9´3AFR or lower under full acceleration and the cars does not work well nothin the nothing,too rich.. ..
