Does the internal diameter of the vacuum pipes make a difference?
I have 3mm ID silicone hose spare from another project,the S2 uses 4mm ID I would prefer to use what I have rather than buy new but dont want to replace at a later date if they will cause a problem...Help please
technically for the physicists yes , can't remember the relative formula I should be quoting, realistically people have used 3/3.5/4mm. they'all work, 4mm would be your best most useful option if thats waht you got, though sometimes it's a right pita using the classic cloth covered 3.5mm
Cheers thanks for your replys ive just fitted the 3mm Samco hose on at the moment and if i do get a problem ill have to change to 4mm...nevermind the 3mm is free so will only cost me if I have to buy 4mm
