Oki my car is running **** rich at the moment.
Running 044 fuel pump with 7A 4bar FPR.
So I installed a fuel pressure sensor from Zeitronix where the fuel enters the fuel rail.
The sensor has the following specs:
Sensor 150 PSI Gauge
Output 0.5 volts at 0 PSI gauge pressure (atmospheric pressure)
4.5 volts at 150 PSI gauge pressure (150 PSI above atmospheric pressure)
At idle the gauge reads 3.5-3.6 bar which seems correct.
But at WOT with 1.7 bar boost (relative) the gauge reads approx. 5.3 bar
Now I'm thinking this is way to much fuel pressure since a 4bar FPR should regulate the pressure to 4bar. But after reading S2central.net thread "fuel pressure revisited" I'm just confused to be honest.
So can anybody help me out to understand how this work?
