Any1 ever had any probs with these. Only reason i ask I used them on my cossie years ago and they cracked the block around the bolt holes. Because they were not stretch bolts like the OE ones instead on them streatching they put so much extra load on the small area i got loads of small cracks which knackered the block. Once this happened i then found out from the RS site that it was quite common
I am looking ahead for when i change the head gasket and not sure if i want to go that route again.
cheers
Paul
cheers
Paul
