Hi,
Fitted a new starter motor to cure that problem over the weekend (a How to will appear shortly) but seems that a new prob rears its head... When the car is started the idle would normally sit at 6-700 but its hunting for a couple of secs before finding the level.
I took the car out for a quick spin, on coming up to a roundabout, dipped the cluth on pulling to a halt and ......stalled
I think it must be to do with either:
ISV?
Lambda?
possible air leak?
Can you suggest anything else to look at......? My instinct tells me its the lambda as the fuel consumption has been creeping up a bit recently but any help appreciated.
Cheers,
David
ISV?
Lambda?
possible air leak?
Cheers,
David
*may* have got upset during the starter motor failure.
