Help with wiring: AAN VS 3B TPS? Problems
  • Jonas_R
    • 3780
    • Country: Denmark
    Ok,
    So today I tested my brand new AAN/ADU/ABY TPS and it only shows 3.8Volt at WOT.
    Now I have converted my 3B ECU to AAN ECU, but something must be different in the wiring used.
    Because with the 3B TPS then I see 4.8V, so I'm thinking that something must be different with the wires going to the TPS.
    Any other suggestions would be nice....
    Because this is strange.
    Sleeper S2 Avant +450
    A6 Avant 2.7t Stage 3
    Audi S2 Coupe RS2'ed
  • Jonas_R
    • 3780
    • Country: Denmark
    So problem sorted, turns out that the crap Multimeter I was using somehow effected the Voltage so it showed wrong readings.
      I know you got it sorted (multimeter issue) but I thought I would add this throttle position potentiometer/idle switch info link:
      http://forums.audiworld.com/showthread.php?p=18930483
      The TPS is common to most Audis from 1989 to 1999, i.e. AAN TPS = ABY = ADU TPS
      EDIT: Apparently the 034 133 154 F 3B TPS is different.
      • Jonas_R
        • 3780
        • Country: Denmark
        There are different part numbers on 3B vs. AAN/ADU/ABY TPS, so are you saying they are the same?
        S2central.net list that they are not interchangeable.
          Originally posted by Jonas_R
          There are different part numbers on 3B vs. AAN/ADU/ABY TPS, so are you saying they are the same? S2central.net list that they are not interchangeable.
          Rechecked info with Kate. She says 034 133 154F = 3B whereas
          078 133 154 = AAB =ABY = ADU (Ref: ACOQ, Illustration 133-72, items 2, (2).
          So I stand corrected about the 3B TPS (Believe Paul N)
          Bugga.
          • Jonas_R
            • 3780
            • Country: Denmark
            Question is what the difference is. I was running a 3B TPS on my 3B which is converted to AAN ECU. I'm having some problems with WOT code not showing in VAGCOM so I thought it might be down to different TPS. But I guess I will know that tomorrow when I fit the newer AAN TPS.
