Sorry for the broad question, but there's just too much info to sift through on the forum regarding chips or 'home fries' as people call it. Here's my set up:
3B motor w/ stock internals
7A exhaust cam
RS2 turbo & exhaust manifold
RS2 injectors
7A FPR
3B ECU w/ 2.5 BAR pressure transducer and Intended Acceleration's stage 3+ tuning (should be good for 380 hp)
I've been running this set up for a couple of years now but it's always seemed to run quite rich. I get a pretty bad smell in the cabin when coming to a stop and fuel consumption is pretty heavy. I also seem to be going through a lot of O2 sensors. All other components are fairly new and in working order. My question is, with this current engine set up, is there a better chip out there that will give me the same power?
Thanks!
Ben
7A exhaust cam
RS2 injectors
7A FPR
Thanks!
Ben
What kind of HP and torque numbers are you shooting for/anticipating?
When I had the ECU tuned, I was told that this exact set up has been dyno'd on a 200 20vt with the same components as my motor and it produced 380 hp. I have been meaning to have this verified but 4 wheel dynos are a bit tough to find around here.
so I bailed on the overnight and just made a day trip (June 23) instead.
