So I have read a couple of threads where it is mentioned that people are running a separate wire for the fuel pump.
So I have a couple of questions to how it is done:
I'm thinking that I take a relay and hook up the +12V and ground from the fuel pump to the relay. This way the relay will turn on the pump when the motronic turn it on.
What amount of current does the relay need to handle?
What kinda size wire do use?
Where do you take ground from?
Do you change the wires inside the tank or just from the plug located on top of the tank?
Any kinda pictures of better explanations would be nice.
hi hi.
