Overboosting.... Help im running out of ideas
    A long shot maybe - with the very free flowing exhaust that you have Greg - could the turbo be overspinning I wonder and causing excessive boost ?
    Was the car mapped with this exhaust system or not ?
    • Mihnea
      • 1288
      Good point Paul, the answer is "not", the car has been remapped with the stock exahust, including cats and standard DP....
      Greg, can u make it to Doug's this weekend or not? Forget the speedo/mileage stuff, we'll sort that out for you
      Cheers,
      Mihnea, soon to prepare stuff before leaving
      www.MRCTuning.com
      info@MRCTuning.com
      Workshop Directions
      • Doug_RS2
        • 3847
        yeah - get up here Greg - If you are running 2 bar boost I want to see how yours feels compared to mine running 2 bar. There will be a few cars here so you can swap bits over if you are really stuck.
          Ahhh see you can tell I have been doing more homework this week huh !
          Been travelling with work this week and have had some chance to get my head round the wonderful world of turbochargers. I have also drafted a paper on 'how to read compressor maps' for us along with some useful calculators in Excel for compressor selection and estimation of air temperatures. Ohhh its good stuff - based on some reference info from Meister Corky Bell, Messrs Garrett, KKK and a few other sites of interest. I'll post it tomorrow when I get the graphics sorted and then it can be reviewed and improved.
          If I get really organised I shall create a web version of the calculators so that y'all can play with various values.
          If my calculations are correct, I can see a GT30R application on the S2 with the right intercooler that produces inlet air temp below 40 degrees C with 1.8bar boost on the redline.
          Paul
          PS - It was something in Corky's book that triggered my thoughts on the turbine overspinning as a result of much reduced back pressure from the exhaust.
            Doug, Mihnea. Would love to come up this weekend but don't think I can afford to this month with petrol and stuff too because got hol coming up next month. I will let you know later on.
            Im gonna try the stock WG spring later as Mihnea suggested and will let you know.
            • Doug_RS2
              • 3847
              #21
              Greg - if you run sensibly you can get up on 1 tank and home on another tank ! I did it during the week!
              It defo sounds like your car needs remapped for your exhaust and non leaky hoses - no way around that.
              I finished mapping mine - well over 400bhp!
                Dont be saying things like that to me now. Mihnea, realistically what power can the standard rods run?
                  Just been out to try changing WG spring and it def isnt to be this eve, first i dropped a nut into undertray then the WG perch so im gonna leave it till the morning and do it properly now.
                  greg
                    ITS FIXED im a very happy chap now. Changed the WG spring back and set the mechanical boost to 0.6 - 0.7 Bar and then connected WGFV back up and its fine again. Replaced my original WGFV from the new one that was fitted and thats fine too.
                    So car is back and running nicely for now.
                    • Beetie
                      • Oct 2003
                      • 1517
                      I was going to ask if i could have some of your overboost as mine still hasn't got any!
                      Was a '93 3B, Dont ask now tho......
                        LOL, still trying to track down the the problem at the min?
                        • Dr H
                          • 1175
                          How do you get that much mechanical boost? With the standard spring really really screwed down mine only makes just under 0.5 bar
                          Paul N siad his only makes 0.4 bar - I think.
                          Ex 1994 Avant - now driving a Lotus 340r
                          • jubjub
                            • Nov 2003
                            • 1239
                            I bet you have a big again.....Greg-what way round is your WGFV fitted?
                              I noticed that today too Jub Jub. On the 3B's it has the little white dot on the otherside to the ABY ones.
                              Its mounted with the long pipe of WGFV into intake pipe, the one opposite to WG and one out of bottom of WGFV to turbo compressor housing.
                                greg
                                Hmm, those nice shiney nuts?
                                Glad you got it sorted Greg!
