I saw on some forums, that some s2 engine, uses nos for a faster spoolup of turbo, what is the idea behind this. Inject nos, until turbo build bost, progresiv ? or how ?
Nos for spool up
I did this on my s2 engine with 35r turbo using a 50 shot.
Basically using the map sensor output to control the nitrous, so when boost is built up the fuel and nitrous solenoids are turned off.
It works.The ONLY S2 Golf!
10.42@138mph
https://m.youtube.com/watch?v=0wnkkOfFpXgComment
Is it possible to do this on motronic? or buy a program/add on I can use.
I will be giving it a go once the mot's done.
I used to be able to build up boost at standstill but I think thats what killed my clutch
some of the other forum members will agree with that comment.
You can easily make this setup using a microswitch on the throttle to activate the nitrous.
Then use an adjustable pressure switch to deactivate the nitrous when your up to boost.The ONLY S2 Golf!
10.42@138mph
Here is a dyno graph for the Roger Clarke impreza, the car that won time attack and totb last year. The graphs are at the wheels:
As you can see it makes another 100bhp at the wheels and 150lb/ft of torque but the way the curves are shifted lower down the revs are the most impressive part.Comment
