Oil line & N75 Solenoid Q.
  • RustyNut
    • 1433
    • Home: Zambia Current: United Kingdom
    Evening All,
    I'm going to replace my standard oil cooler with a 13 row Mocal or similar but i'm not sure what fittings I need for the oil lines where they connect to the filter housing (see pic).
    Does anyone know what size and type of fitting i need to request?
    Secondly i'm going to replace the N75 with the Turbosmart solenoid but i'm not sure which is the best direct replacement. I looked on their website and found these http://www.turbosmartonline.com/index.php?id=43 . Am I looking at the right ones and if so which is best?
    As always, appreciate your help
    Russ
    Old Stuff Reborn.
  • Bram
    • Aug 2006
    • 2582
    You will probably need a remap of your motronic ECU software once you replace the N75 with an aftermarket one.
      the line fittings will be metric i'm sure mate, not sure of the thread. You should be able to find everything you need on www.speedflow.co.uk
        M18x1.5
        Your on the wrong page for the solenoid TS-0301-3003
        • GazzaG60
          • 4133
          so you fit a turbosmart solenoid and then have it remapped, be a test subject and all.
          why not just get an n75 or a full eboost. will be cheaper and less likely to have issues.
          fiull eboost set to 1 bar will be nice. BTDT
          • RustyNut
            • 1433
            Thanks chaps,
            The car will need a remap anyway due to the build ( http://www.s2forum.com/forum/showthread.php?t=37387 ) and i'm considering the Turbosmart solenoid after reading the various threads on the subject that generally suggest it is more reliable? I'm still a bit green when it comes to the various options regarding the N75 and figured it was best to fit something that either works better or makes the mapping process easier. If I hadn't seen the threads regarding alternatives I would have just bought a new OEM N75 and thought nothing of it. Is this still the best way to go or do you suggest I continue down the alternative route and if so which one?
            Russ
            Old Stuff Reborn.
            • RustyNut
              • 1433
              Still need more help with the oil lines... Has anyone had some lines made up to fit on to the filter housing? I've got a Mocal cooler with 5/8 threads and fittings that i can easily have hoses crimped to but I can't find a supplier that has the same fitting that the OEM lines have that fit to the housing... The OEM ones have a domed end with a rubber sealing ring inserted in the domed section. Can anyone help either identifying what type of fitting this is or have details of somewhere i can get such fittings? Need them real quick as my car has to get started and leave the garage pronto!!
              Russ
              Old Stuff Reborn.
              • terrybullwon
                • Mar 2006
                • 8782
                Russ you need to use some -8 or -10 line. Give Speedflow or earls uk a call. Also some
                You will need,
                2x M18 1.5 to -10
                2x Female 5/8 BSPP to -10
                Then the fittings so you may need 2x 45deg and 2x 150 or 180 degs? You will need to sus this out though.
                Good luck
                Chef
                • RustyNut
                  • 1433
                  Cheers James.
                  I've got two 90deg 5/8 fittings for the cooler end (i've mounted the cooler above the IC on the IC bracket) and agree will prob need two 45's for the filter end. What does the -8 & -10 refer to? Will speedflow or Earls have the same type fittings as the OEM lines with the rubber seal? I preferably just need the fittings with a section i can get some hose crimped to if poss.
                  Do I even need to use a fitting the same as the OEM ones at the housing?
                  Russ
                  Old Stuff Reborn.
                  • terrybullwon
                    • Mar 2006
                    • 8782
                    what are the two 5/8 fittings you already have? re-usable?
                    Chef
                    • terrybullwon
                      • Mar 2006
                      • 8782
                      AN is Army / Navy . - is just the size
                      If you look here i have some in -12 to the oil cooler
                      Chef
                      • RustyNut
                        • 1433
                        I bought them with the cooler, haven't fitted any hose to them yet. They're exact same as these but a 5/8 fitting http://cgi.ebay.co.uk/Mocal-Steel-1-...4#ht_720wt_713
                        So your AN fittings go straight on to the housing? Do they have the rubber seals or are they not necessary?
                        Old Stuff Reborn.
                        • terrybullwon
                          • Mar 2006
                          • 8782
                          they might work with some push lock hose like on the speedflow web site. If not you might have to change and go with the convertors and proper AN fittings and hose
                          Chef
                          • RustyNut
                            • 1433
                            I looked at similar AN fittings in the shop where I was going to get my hoses/lines made and they claimed the AN fittings wouldn't work at the filter housing end... Have you got any more of the ones you used?
                            Old Stuff Reborn.
                            • terrybullwon
                              • Mar 2006
                              • 8782
                              Looks like this will work in the -8 Size As that comes back to the 1/2"
                              Bah its because the fittings are metric. They wont susport the AN fittings this is why you need the adaptors for the filter housing like i have.
                              Speed flow will have them in stock
                              Chef
