id have a guess at a compression test is not quite right. this can be many things. onyl way is to take her apart.
my experience with no compression was counting fron front. 1 ok, 2 ok, 3 ok, 4 ,ok, 5 none.
inspection saw that cam had snapped between the 2 lobes on 4 so had a valve stuck closed all the time. on 5 both were stuck open all time. no damage caused, except to drop another cam in.
the garage may have used the old its ****ed line as a stripdown in labour may cost 1/2 new engine. also they may not want to dabble with such a costly engine, maybeb dont know enough. however it may cost next to nothing except labour to put right.
id have a word with tom if you are not into stripping engines. ask him to flip the top off for you and give his opinion. maybe a few quid well spent.
