3b and aby cylinderhead/ engine block
  • _Denner_
    • Jul 2009
    • 15
    • Country: Denmark
    Hey
    I just wanted to hear if any of you know if i can fit my old 3b cylinderhead to an aby block, my old cylinderhead is modifyed so that would be nice to use that again
    I hope some of you can help me
    Denner
    YES is the short answer
    If you are using direct ignition (ABY) then will need to install camshaft sensor on the 3B head and make up a blank plate for where the dissy would have been... unless you wish to retain 3B distributor as just a location for camshaft sensor.
    • _Denner_
      • Jul 2009
      • 15
      • Country: Denmark
      Im still using the 3B distributor, i was more thinking about the oil and water lines/channel, are they at the same place or will the 3b head block some of thoose
        galleries and channels all the same denner. Bolt on, drive off
        • _Denner_
          • Jul 2009
          • 15
          • Country: Denmark
          Perfect thanks guys..
          • Jonas_R
            • 3781
            • Country: Denmark
            Hey Denner,
            Are you putting the 6 speed gearbox on a 3B?
            Sleeper S2 Avant +450
            A6 Avant 2.7t Stage 3
            Audi S2 Coupe RS2'ed
            • _Denner_
              • Jul 2009
              • 15
              • Country: Denmark
              Jonas, yes thats my plan, but its a bit harder to fit then i thougt
