Originally posted by newsh
Weird Air Leak
Paul, why don't you pressurize the whole system, including the crankcase vent system???? If you have a leak in one of the breather hoses, you won't be able to see it if you block the breather hoses off when pressurizing.
I always check the whole system and make sure there's no leaks in the breather hoses, and it's never played trick on me so far...
Cheers,
Mihnea'98 Silver Grey 2.7T S4, dual 2.75" turbo back exhaust with no cats, FMIC, BIG injectors, 10 Bar motorsport fuel pump, modded RS4 turbos, tubular exhaust manifolds, custom intakes, RS4 MAF, Bilstein PSS9, H&R ARBs, 19" BBS CH, custom remap, 511 BHP/505ft-lbs
www.MRCTuning.com
info@MRCTuning.com
Workshop Directions
My car leaks a bit thro the turbo seals. Shaft has a little bit of side to side play, but not excessive. I would like to pressurise my car at Billing too. Im ******ed if I can find a leak. I bet its dead obvious and a sod to fix!!sigpic
Tom C - www.rcmr.co.uk
Audi UR Quattro
Audi 100 C3 2.0 5 cyl 115ps
Audi B5 RS4 645ps 911nm
Done mine :nana: Comes complete with rear housing housing. About 40 quid from memory? Gearbox and flywheel off job tho But then if that was leaking badly enough to cause running issues, would you not have a large trail of oil in the bellhousing that seeps out??
Im not saying it isnt that as i have never come accross this.
But also, the inlet side of the turbo isnt subject normally to 2 bar of boost pressure. Maybe i have a dying turbo then. Its only 18 months old topssigpic
Audi UR Quattro
AFAIK turbos are supposed to have a bit of play side to side, not end float though.
Originally posted by audimanDone mine :nana: Comes complete with rear housing housing. About 40 quid from memory? Gearbox and flywheel off job tho But then if that was leaking badly enough to cause running issues, would you not have a large trail of oil in the bellhousing that seeps out??
As Newsh says a screeching noise is sometimes present, which is the air being sucked in.
The problem with how you recieve the new housing/seal is that you are limited to were the seal sits on the crankshaft, if the old seal has worn a groove in the crank shaft, then you need to move the seal so that it will sit on a clean bit of shaft.
It "MAY???" not be the correct diagnosis for this situation but if you guys with the newer stuff are having air leak issues consider the problems that us older stuff guys have already experienced?
A good way to tell if the crankshaft oil seal is leaking is, place a long metal rod on the bell housing (engine running) and place your ear on the other end. Think of it as a stetherscope, you will be surprised what you can hear.Corey
01636 822288
Point taken Corey, im sure that this would cause a poor running situation. Maybe pressurise the whole system as Mihnea said, that way it will show up any dodgy oil seals and the like. I have replaced all the breather hoses on mine now(kerching, not cheap). I will get to the bottom of it hopefully at Billing. Weather permittingsigpic
Audi UR Quattro
When my rear crank seal had gone, it wasn't leaking, but was making a bad screetching noise.... Was presuring the engine internals alot, you could also tell by taking the filler cap off and the noise will stop...Was a '93 3B, Dont ask now tho......
Fair shout, i have never come accross this. something to look for in the future!
They say that you learn something new everyday!sigpic
Audi UR Quattro
Originally posted by Greg_SWhat sort of noise was it making? sometimes if car has been standing a few days you get a squeaking noise until the oil pressure is up.
GregWas a '93 3B, Dont ask now tho......
If you pressurise the whole system without blanking PCV hoses then you just end up pushing air past the oil filler cap and piston rings - air then escaping thru whatever valves are open.
I'll get a bung so I can pressurise the PCV system right up to the valve on the crankcase as that will test a few more hoses and joints.
I'm planning on deleting the PCV system anyway after seeing how much oil vapour gets circulated in the turbo hoses.
PaulPaul Nugent
Should there be vacume present when i open the oil filler cap while the engine is running, i have no gasses coming out and i couldnt feel much if any vacume, and it didnt make the slightest difference on the cars tickover. The car was cold.
When i start the car up i get one puff of blue smoke on the first rev then none for the rest of the day. I have put in new stem seals so it cannot be them, my turbo is slightly worn and it also has a blocked fuel filter so i am avoiding using it till Friday (payday). But could the smoke be whats sucked through the PCV system as mine did show signs of a leak but i couldnt find it.
GrahamEverything should be made as simple as possible, but not simpler.--:Albert Einstein
