burning smell
  • l455lnk
    • Oct 2006
    • 6
    burning smell
    your help please gentlemen
    i have a 94 aby S2 and after 15 mins or so of starting i get a strong bitter sweet burning smell inside and outside the car
    i cant pin it down to anything in particular
    has anyone had a similar problem ?
    cheers
    paul
  • turbo s4
    • 58
    • Country: Belgium
    seems a coolant leak
    tom
    • l455lnk
      • Oct 2006
      • 6
      thanks il check
      not lost any fluid as far as im aware tho
      cheers
      paul
      • jameswkr
        • 538
        If your neighbours can stand it..try leaving it ticking over from cold....until it is using the cooling fan...then look round the engine. If no leaks and no smell..then...
        I would go for brake fluid or PS fluid leak. Should be easy from there. Road test...
        Pls let us know what you find. Cheers James.
        • Ian Simmonds
          • Jun 2005
          • 2858
          Silly question...
          Have you laid underneath the car and had a look. Years ago, with my old GT, I had a carrier bag melt onto the exhaust downpipes... It stunk for ages afterwards as I was only doing short runs in it. Might be as simple as a carrier bag (or similar) stuck on the CAT or wedged up on the exhaust.
          93 MTMS2 Avant
            That smell.... is your wallet melting
            • s2driveruk
              • 12696
              gearbox output seal leaking made mine smell of burning rubber kinda smell
              1992 3b S2 Coupe
