your help please gentlemen
i have a 94 aby S2 and after 15 mins or so of starting i get a strong bitter sweet burning smell inside and outside the car
i cant pin it down to anything in particular
has anyone had a similar problem ?
cheers
paul
If your neighbours can stand it..try leaving it ticking over from cold....until it is using the cooling fan...then look round the engine. If no leaks and no smell..then...
I would go for brake fluid or PS fluid leak. Should be easy from there. Road test...
Have you laid underneath the car and had a look. Years ago, with my old GT, I had a carrier bag melt onto the exhaust downpipes... It stunk for ages afterwards as I was only doing short runs in it. Might be as simple as a carrier bag (or similar) stuck on the CAT or wedged up on the exhaust.
93 MTMS2 Avant
