As part of a process of elimination to finally eradicate the cause of the dreaded (!) symbol and three annoying beeps Im going to try swapping the brake fluid reservoir/tank. I think there’s a float in there which can cause problems. I know the tank basically plugs into two grommeted holes on top of the master cylinder and can be pulled off. Other than draining the excess fluid out of the tank is there anything to look out for? Also will I need to bleed the brakes afterwards?
The warning symbol seems to be level related. Sharp movement, or even just pulling away will set it off and it’s the bane of my life! Been on the car since I bought it and never got to the bottom of it. I know the bomb is good as it takes a about 50 or so pumps for the pedal to go hard. I’ve swapped and cleaned the float / cap on the power steering pump reservoir to no avail. Even totally unplugging it seemed to make no difference either. Same with the little grey sensor under the brake fluid reservoir. Swapped that for a spare and it made no difference, as did totally disconnecting it. Ive just swapped the two pin brass sensor that’s tucked away right under the master cylinder - no difference. The warning light normally comes on about two seconds after I pull away. Sometimes later, but usually not much Admittedly, I not used brand new replacement bits and I could just be that unlucky – and I will buy new if the tank doesn’t work.
I could still have the levels themselves wrong. Its not that easy to judge what the correct level for the power steering fluid should be in the tank – the level mark is hidden and is that level supposed to be with the tube-like filter housing in? Brake fluid to be honest should be changed as its been in probably too long, but it must be a sensor of some sort
Paul.
Paul.
