VAG Com mate. Drop me a PM.
poor starting
its like the M4 VAG.com corridor
still de-gunking the intake but cheers guys for the nod
1992 3b S2 CoupeComment
VAGCOM is your friend here as you can check what the ECU sees as water temperature - check S2central.net for 3B details on Group 0
Your oil spumage at ADI might have messed things up if it has fouled lambda and/or MAF with oily filf.Paul Nugent
yeah, the oil had gone up as far as the maf looking at the pipework, would the burn-off cycle cure that or does it need help with IPA or something do you think?sigpic
Burn-off will help, but I suspect not much if its got a proper dousing... could be worth a pint of IPA. Trying a spare/borrowed MAF first of all should be the clincher.Paul Nugent
or me when your next in the area
