I have tried everything to get rid of the mid range stutter my car has, vacuum, ignition, etc. (No problems there although the odd knock sensor fault but that’s tomorrows job!) The only thing left is the fuel pump and I have had it on good authority, that I might not be getting enough fuel into the engine with the MTM map! As slow acceleration it’s quite rapid but on WOT and 2/3 throttle it stutters!
What would be a good replacement ‘New’ fuel pump and I suppose regulator, to replace one that’s done “114000” miles? (UK supplier if possible!)
Now that the exhaust is done, if you exclude the suspension and other bushes I will get replaced, this is the last issue to sort!
Many thanks once again,
Andy.
Andy.
