urs4 aan not running well
  • pasbogdan
    • Sep 2009
    • 1160
    • Country: Romania
    The car "suffered" an automatik to manual swap.
    I had to bridge some conections at the ex auto gearbox cable so the car thinks that the lever is in n or p so i can start it.
    When applied full throttle the car is not running smoothly and for a seccond is running like a turbo and for 5 secconds like a non turbo(NA)....
    Tomorow i'll be mounting the boost gauge to see the what boost it has when it does not accelerate...It seems to me it is a spark problem when under boost,but i'm not realy shure.
    Could be the ecu?(it is from an auto gearbox car).It thinks i'm in n or p and that's why i dont have powe under boost?
    thx,
    hope you'll be with me in trying to solve this...
    That is a good guess. The engine ECU for automatic AAN cars is different than the cars with std transmissions. Suggest that you find a std trans AAN ECU and try it to see if that is the problem.
    • pasbogdan
      • Sep 2009
      • 1160
      • Country: Romania
      SOLVED!!!(allmost)
      Made the conversion to 1.8 coils.(thanking the autor of the scheeme)
      After 2 hours of running,piston 3 started to have problems...It is not the coil,i have put the coil from nr 1 at nr 3 and viceversa,and when i disconect the injector cabble from THE SAME NR 3 feels no difference...
      So....spark plug?all 5 are new(bosch,the right code),but they runned 2 days on car with the bad coils.....i'll try to to change the spark plug from 3 to one from 2 and try to disconect the injector cabble again to see if it is a spark problem.
      Somebody experienced injector faults?When smoothly pressing the gas pedal until half and after that full throttle the nr 3 is running ok.IF full throttle is pressed from the begining nr 3 piston is in holiday and the oders are working for the UGLY nr 3...
      Regards,
        I'm not sure this will run properly unless the ECU is using chipset for manual AAN - chips from 4A0 907 551 AA or A. I can help with that if you wish - or you might be interested in upgraded AAN setup - though sounds like you should get running nice and clean in factory setup first of all.
        • pasbogdan
          • Sep 2009
          • 1160
          • Country: Romania
          The car is starting to run better(by it self).
          The spark blug from 3 has a broun red colour(seems to run with less gas than the others).
          I'm interested in changing the cip from ecu.Pm me please with more info about upgrades,costs,delyvery,payments etc
          Regards,
            SOLVED!!!(allmost)
            You're welcome.
