I've broken 2 alternator belts and one pas belt in the space of 50 miles.
Obviously something was wrong
so today decided to investigate....
Turns out the crank pulley is rotating off center, bit like a cam if you know what i mean?
It's not by much, maybe 2mm but i recon probably enough to stress a belt.
Been looking at the ETKA and it seams it comes in 2 pieces the damper and the belt pulley (ABY). Any one had any problems like this b4?
Started to remove the pulley today but broke the 1/4" extension on the 3rd bolt and need to drill the broken bit out of the socket
It was getting cold and very windy so gave up for the day.
so today decided to investigate....Turns out the crank pulley is rotating off center, bit like a cam if you know what i mean?
Looks like the car will be off the road for a bit, getting married on Saturday so funds are shall we say a bit limited
innit met
