Fitted another metering head to try and resolve an idle issue in where revs would keep dropping till stall when coasting up to lights.
Turns out that the one that was on there had the little hole for adjustments tampered with, stuck the new metering head on ran like a treat although a few attempts to start from cold.
Just went to my car and it will not stay on, it starts for a second is lumpy as hell and revs just drop and die.
Have replaced lambda sensor so that is not the issue, I am thinking it could be my idle regulator.
Any suggestions pease, keep in mind im not a wizard with cars so please in basic terms
