Found a couple of hours today to get on with my big IC installation after removing the aux rad last weekend. I acquired the crossmember shown in the pic below which I think is one of those which s2_bo hade made up a couple of years back.
A problem I came across is that the XM won't fit properly due to the snub mount on the front of the engine. It fits ok if i take the rubber part off but don't really want to leave it like that. Ideally i think i need a rubber mount with a smaller diameter or a different bracket which would lower it by half an inch or so. Does anyone know of substitute parts I coud use? If anyone has fitted one of these XMs or similar and has any advice your help would be great.
Incidentally my car is an ABY coupe and has air con whch I'm happy to remove it if it makes a difference...
Easy fix if it is
(why you using a 3B xm anyway?)
