Car is 200 20V, 3b engine with RS2 components.
After installing all RS2 components, car never run like it should (boost almost nonexistent under 4500 rpm, lean mixture at same rpm range; according to AFM connected to standard lambda). MAF was the suspect, so I tried 4 different MAFs available to me and car was running beter with one of them, but not even close as it should.
However, it got even worse today; car just stalled. It can be restarted, but it's running only if I apply throttle, very bad, and producing a lot of smoke. When I disconnect MAF connector, it run "normal" eg. as it should with disconnected MAF.
Did anyone have experience like that ? I will be checking connector and wires leading to MAF, but can someone give me some useful hint what to start with ?
Thank you,
Mario
Thank you,
Mario
