S2 to RS2 setup
  • bartolomeus
    • Jan 2009
    • 1475
    • Country: Romania
    S2 to RS2 setup
    Hello
    I have an Audi S2 with the ABY engine and I saved some money to upgrade the engine to RS2 performance.
    Does anyone know what parts do I have to change so I can have the RS2 perfomance? I mean that I know that I have to buy an RS2 turbo, RS2 injectors,... and so on... but what about the other parts?
    Is there anyone here that upgraded his engine from S2 to RS2?
    Thanks.
  • aRtiS
    • Nov 2008
    • 989
    • Country: Latvia
    Originally posted by bartolomeus
    Hello
    Thanks.
    I've got some parts you would be interested in.
    Please specify exactly what you need and ask.
    Audi RS2 600 hp
    Audi S2 1200 hp
    MB 230E '83
    https://www.facebook.com/ventracing.lv/
    • Jonas_R
      • 3781
      • Country: Denmark
      You would need:
      RS2 injectors or Light green bosch injectors (they flow a bit more but are less expensive since they are used on some ford pickup trucks).
      RS2 turbo
      RS2 intercooler or Wagner EVO RS Intercooler (I would go with the wagner item)
      RS2 Exhaust Manifold or Wagner EVO RS Exhaust Manifold (I would go with the wagner)
      Vmap-D 3bar mapsensor or bosch 3 bar mapsensor.
      Perhaps a 3" downpipe
      Remap
      Sleeper S2 Avant +450
      A6 Avant 2.7t Stage 3
      Audi S2 Coupe RS2'ed
      • bartolomeus
        • Jan 2009
        • 1475
        • Country: Romania
        Hi
        Well, I need:
        RS2 turbo
        Thanks.
        • K Simmonds
          • Dec 2007
          • 7627
          For RS2 conversion you need.
          Essential
          RS2 Exhaust manifold.
          RS2 K24 7200 Turbo.
          RS2 Injectors.
          RS2 ECU or equivalent chips and map sensor.
          Optional but worth it.
          RS2 Downpipe, or 3" down pipe.
          RS2 Intercooler and cross-member, or the original cross-member can be modified.
          RS2 Airbox
          Up rated fuel pump.
          1990 B3 2.0 80 quattro.
          1992 C4 2.8 Avant quattro
          1994 MTM RS2.
          1998 B5 TDI quattro Sport.
          2000 B5 TQS.
          • aRtiS
            • Nov 2008
            • 989
            • Country: Latvia
            As I don't have rush very big discounts are not expected, sorry, but at the same time, it would be great my RS2 parts would go to honesty true Audi enthusiast.
            Injectors - 250,00 euro
            EM - 320,00 euro
            IM - send PM
            intercooler - send PM
            Postage costs, transfer commission or 3,4% Paypal commission is not included
            Sending costs by courier (DPD) from Latvia to e.g. UK are ~ 51 euro
            Audi RS2 600 hp
            Audi S2 1200 hp
            MB 230E '83
            • bartolomeus
              • Jan 2009
              • 1475
              • Country: Romania
              See above. Thanks.
                Essential
                RS2 K24 7200 Turbo.
                RS2 Injectors.
                RS2 Airbox
                Up rated fuel pump.
                Larger Downpipe is essential, 2.5 has way too much back pressure to use with RS2 turbo, if you do your stuck with about 320 bhp.
                Your remapper will also tell you change to the downpipe.
                The exhaust system needs to be optimised pre mapping
                • valjo
                  • 1110
                  • Country: Latvia
                  hi!
                  if i were you i will change those parts too:
                  -camshafts
                  -airbox
                  Audi Coupe S2 1993
                  Audi V8 4.2 1993
                  Audi cabrio 1998
                  • JamesHarrold
                    • Feb 2008
                    • 245
                    Hi guys....What about.....CON RODS!
                    James
                    • max_s2
                      • Mar 2006
                      • 498
                      • Country: Latvia
                      The are the same as in an ABY.
                      • 20Vcqdriver
                        • 829
                        James
                        Depends on how much he is going to upgrade it once the RS2 parts are on. I am uprating the rods on mine purely to ensure the bottom end is bomb proof for when I go RS2+ on mine!
                        1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
                        • pixsaudisex2
                          • Sep 2004
                          • 3110
                          yeah but for rs2 power no problem. the problem is why bother going rs2 you would be better skipping that bit and going straight for serious bhp...
