im thinking of going for an 044 fuel pump for my ABY to try and cure some stuttering and the lean running it showed up previously on the dyno.
apart from a homefries, roose hoses and a bailey DV its a standard engine.
Would an 044 be too much for it, possibly causing it to go rich, or would the FPR & lambda compensate for this? Car is currently running a 4bar FPR.
the whole point of going for the 044 over a standard is that at somepoint in the future i wouldnt mind going 3071r or similar.
Cheers.
Cheers.
