RS2 Fuel Pump part numbers
  • Golfboy666GTI
    • Sep 2008
    • 571
    • Country: New Zealand
    I understand that the factory RS2 part number is 895906089E
    Also this pump is made by Pierburg.
    The Pierburg from what I understand is: W0133-1598495
    and also fits the below cars:
    Fits these Vehicles
    1989-1991 Audi 100
    1989-1991 Audi 100 Quattro (443906087BD, 895906089E)
    1989-1991 Audi 200
    1989-1991 Audi 200 Quattro (443906087BD, 447906091E)
    1990-1990 Audi Coupe Quattro (895906089E, 8A0906091G)
    OEM Numbers
    443 906 087 BD
    895 906 089 E
    447 906 091 E
    8A0 906 091 G
    This has been done with my research only, someone else with more knowledge than me (not hard) might like to confirm this?
    1980 VW Golf GTI Track Car
    1995 Audi RS2
  • Golfboy666GTI
    • Sep 2008
    • 571
    Also, according to Bosch E-Cat the Bosch part number is 0 580 254 040
    1995 Audi RS2
    • |Maku|
      • Apr 2005
      • 248
      • Home: Estonia
      Here you an see ADU vs AAN fuel pump.
      • Golfboy666GTI
        • Sep 2008
        • 571
        Can anyone please advise what the correct RS2 fuel pump part number is?
        Is this pump shared with any other cars?
        Do we know any other part numbers?
        My RS2 has done 240,000kms, the fuel pump is getting loud so I think it might be time to replace it.
        1995 Audi RS2
          Originally posted by Golfboy666GTI
          ...someone else with more knowledge than me (not hard) might like to confirm this?
          Don't know if I qualify or not Nik but I think the answer is here:
          General G6 Fuel Pump info including links to R&R DIYs: http://forums.quattroworld.com/s4s6/msgs/22623.phtml
          RS2 Fuel pump PN:
            Your link is broken. It would show that the RS2 Fuel pump and the AAN fuel pump are both 43 mm in diameter but that the RS2 fuel pump is taller than the AAN 091G.
            • re2500
              • May 2007
              • 2185
              I can confirm i found a RS2 pump in my 1990 Coupe Quattro 2.3E. (I had to check the pump when i fitted the ABY engine to ensure it was man enough) But i am afraid i cannot tell you if it was in there from the factory or not. Perhaps a previous owner upgraded it, but the list above suggests that it it possible that it was original.
              "Difficult is worth doing"
              • Golfboy666GTI
                • Sep 2008
                • 571
                RS2 Fuel pump PN:
                Thanks Dave.
                I put the part number 895 906 089 e into http://www.autohausaz.com/search/pro...0906%20089%20e
                It came up with PIERBURG - W0133-1598495 which only seems to come up as a ur quattro/200 pump:
                http://www.carid.com/1991-audi-quatt...m-7864945.html
                Do you think it would be the same pump and bolt into the RS2?
                1995 Audi RS2
                  I know the RS2 FP is 43 mm like the 091G AAN pump but it is considerably longer, as shown in the autohauz listing (see photo). As for the cross-references, remember than Arizona autohaus is in the USA and the USA never got any RS2s. However, the US did get UrQs and 200 20VTs so the cross-reference for 895906089E does make some sense (to me).
                  • Golfboy666GTI
                    • Sep 2008
                    • 571
                    Thanks Dave.
                    Im after a straight replacement pump. I wonder what other cars share the same pump as the RS2?
                    1995 Audi RS2
                      Thanks Dave. I'm after a straight replacement pump. I wonder what other cars share the same pump as the RS2?
                      Here is the list of the Audi models that shared the RS2 fuel pump (more correctly the RS2 fuel pump was borrowed from them). Note that if it says, for example, A6/S6/Avant quattro, it doesn't mean the AAN in the UrS6, it can mean the ACE 4 cylinder or the AAR five cylinder gas engine.
                      • Pembo
                        • Aug 2004
                        • 295
                        I use a Bosch '040' pump in the rally car. This is NOT a 43mm pump.
                        See this link for info.
                        http://audisrs.com/archive/walbro-25...__t_23509.html
                        Pembo
                        quattro - Original 4WD rallying
                        Rally Car photos
                          Originally posted by Pembo
                          I use a Bosch '040' pump in the rally car. This is NOT a 43mm pump. See this link for info. http://audisrs.com/archive/walbro-25...__t_23509.html
                          Questions:
                          1. Is the 040 in a 60 mm basket or a modified 43 mm basket?
                          2. Is three-tabbed mounting bracket of your design (kudos if so) or is that a 034 bracket?
                          3. What is the strainer on the bottom of 040?
                          I need to do a 044 on my 93 UrS4
                            Thanks Dave.
                            Gotta say Nik but for the same price (around $340 (or less)) you can get a genuine 044 Bosch Motorsport pump that will provide you with more than enough flow and pressure to meet your likely upgrading demands, e.g. chip set to 380 hp with no problem.
                            • Pembo
                              • Aug 2004
                              • 295
                              044 pump is NOT an in tank pump. The 040 is 'comparable' to the 044 but is the in tank version. Think about your fuel pressure you run and the flow rate needed. The rally car does about 5 mpg at max attack and there has never been a fuel pressure problem at 4 bar. I am thinking of going to 5 bar, bigger injectors and I'm not expecting any drop in pressure. Pressure sender fitted to fuel rail and pressure gauge inside car so I know at all time what pressure is there.
                              The 040 does sit in a basket that seems to be standard in most of the Coupe tanks. (I have a spare if you need photos emailing)
                              Pembo
                              Rally Car photos
