Diesel 2.5L crankshaft...
  • Mihnea
    • 1288
    The head gasket is only an issue in the 3Bs with their ancient ignition systems unfortunately, Audiman has blown the paper head gasket with only 1.5 Bar boost from a K26/27 whereas quite a few friends of mine are running RS2 turbos on S4s (AAN engines) with 1.9 Bar overboost and 1.7 after the overboost, 1.1 Bar at 7000 RPM with paper head gaskets and no issues whatsoever at all! Another good example is Mark Halligan, I used to be quite worried about his head gasket (real paper) running that huge Garrett and 1.9 Bar peak boost pressure but now I'm not so anymore, I know that the only problem with paper head gaskets is the spark intensity and accuracy. On my coupe I've already installed a special AAN-3B wiring harness, an RS2-ed ECU and I'll be installing a metal head gasket from Victor Reinz as well.
    www.MRCTuning.com
    info@MRCTuning.com
    Workshop Directions
    • martinjs
      • 3205
      mihnea did you get my mail?
      martin
      • Mihnea
        • 1288
        yup m8, sorry I didn't reply yet.... will do this afternoon if you don't mind...
        www.MRCTuning.com
        info@MRCTuning.com
        Workshop Directions
        • Martynf
          • 1885
          Damn those VAGparts boys are way too cheap!!!
          Actually... that gives me an idea... could everyone who has bought parts from us please donate £5 for every £100 they spent as a thank you, that way I can then afford to get my 2.5 engine job done and a set of BBS wheels that I want :-)
          Drove my S again today for about 40 miles, everything seems in order :-) except for the stink of hot anti freeze :-( Now I can turn my attention to more enjoyable things on her :-), like driving it!
          Martyn
          www.vagparts.com
          • audiman
            • 4827
            I cant afford to pay you the donation. Ive spent too much!!! Hahaha. Glad the old tub is back on the road. Rattling around Kent
            Would love a 2.5 bottom end. But funds are gone, no more car money
            Now struggling to put fuel in the bitch.
            Tom C - www.rcmr.co.uk
            Audi UR Quattro
            Audi 100 C3 2.0 5 cyl 115ps
            Audi B5 RS4 645ps 911nm
            • martinjs
              • 3205
              ill make a donation.....
              for your new slippers!!!:nana:
              • Martynf
                • 1885
                oh well... at least I get a pair of comfy new slippers then
                Martyn
                www.vagparts.com
                • Albert
                  • 1500
                  • Country: Poland
                  #23
                  thanks for the response i will soon see how muth torque will 2.2T take ... i will update You soon with some facts.
                  AKmotorsport.net - Manufacturing Motorsport parts that do the job. | Audi S2 on Facebook | Best way of reaching me is sending email to albert@akmotorsport.net
                  • auditude
                    • 407
                    Originally posted by Mihnea
                    My project is to make 450 reliable HP and 550-600 Nm in my coupe, with a bone stock crank and reinforced rods only, we're going to see if the crank is the weakest link or not but I have a feeling it's not...
                    Mihnea,
                    What type of reinforcement will be done to the rods? Shot peening?
                    Is that project going to use stock bore and compression ratio (well, stock pistons)?
                    Thanks,
                    Ken
                    Kenneth
                    1990 Coupe quattro
                    1991 200q20v x 2
                    1985 4ksq 20vt project
                    1986 Coupe GT 10vt project
                    2006 Honda Ridgeline
                    1998 Honda VFR800FI
                    • caterpillar
                      • 2480
                      #25
                      DON,T use org rods with more than 400hp,you will bend them!!! call +461412220010. it may bee the cheapest and the best.org crank, will stand about 1000hp.tune it!!!
                      • auditude
                        • 407
                        What's that number for? Is that a source for rods? What brand?
                        Thanks,
                        Ken
                        Kenneth
                        1990 Coupe quattro
                        1991 200q20v x 2
                        1998 Honda VFR800FI
