my small project start before one week, and i decide to do a "oil caugh can".
i was using a reciclator from air condition.
cut them on 2 pices:
inside is one pipe and some filter.
i take this out :
put inside is one plastic (something).
i fit that back because the air mix with oil can fall down.
on the ohe other side must be one whoole that you can pull the oil out.
tomorow will be ower because can have to be fited together.
i use this reciclator from audi v8.
with few modification i have a original AUDI oil caugh can....
i take this out :
