RS2 engine rebuilding, what are the best components?
  • Audi-Porsche Avant RS2
    • Sep 2008
    • 1041
    • Country: Italy
    Hello friends, I have decide to rebuilding the engine of my RS2 also if is not really necessary because the oil problem is caused from the turbo, but I prefer also rebuilding the engine. I want change all the 20 seal valve steam and all the 5 piston ring, so I need also a new head gasket and new head bolt. What are the best components for you? The OEM Audi or not?
    Thanks a lot!
    Bye
    Alessio
    My life and my loves
    Audi S6 C4 ABT Avant
    Audi S2 Coupe ABY
    Audi S2 Avant
    Audi Cabriolet 2.0E
  • pixsaudisex2
    • Sep 2004
    • 3110
    valve guides as well if your going to do all that. id have thought.
    • rs200
      • May 2009
      • 1398
      • Home: Croatia
      the head gasket OEM is super, VIKTOR REINZ IS OK
      if you will change a crankshaft berings use a KOBELN SCHMIDT (but it must be SPUTTER)
      head bolt -the best are ARP
      if you are not shure what to take- find something (made in Germany).
      • Avanter
        • Nov 2008
        • 35
        • Country: Latvia
        My ABY repair table (~ 3 months ago).
        Details
        VAG OEM code, detail, QTY, alternate producer (All other parts from VAG)
        034198025F Cylinder head cover gaskets, set, 1 (Victor Reinz)
        034103727 Cylinder head cover gasket, 1 (Victor Reinz)
        034103383AD Cylinder head gasket, 1 (Victor Reinz)
        034103385C Head bolt, 12
        074103609F Gasket for oil sump, 2 (Victor Reinz)
        034105701007 Connecting rod bearing shell, lower, standart, 5
        034105701B40Z Connecting rod bearing shell, upper, standart, 5
        034198491C Crankshaft bearings, set, 6 pcs., 1
        035198421 Thrust washers, set, 4 pcs., 1
        034133073H Throttle valve gasket, 1
        034129717K Inhaust manifold gasket , 1
        035906149A Insert for injector, 10
        06A115561B Oil filter, 1
        447253115 Turbo- downpipe gasket, 1 (Victor Reinz)
        857253115 Wastgate- downpipe gasket, 1
        034145710B Bypass, S2 stock, 1
        027121139A Water cooling gasket, 1
        191129620 Air filter, 1
        035145757D Gasket, turbo oil cooling 1
        035145773D Gasket, turbo oil cooling 2
        N 0138128 Gasket, turbo water cooling 1
        N 0138149 Gasket, turbo water cooling 3
        035129589D Turbo- exhaust manifold gasket, 1
        441201511C Fuel filter, 1 ( Mann)
        026198151A Piston ring kit, 3 rings for each piston, standart size. 5
        027103419 Engine head valve guide, 20
        027109675 Seal- valve stem, 20 (Victor Reinz)
        Engine oil, 5 liter
        Antifreeze G12, 9 liter
        All new exhaust manifold, turbo studs. Maybe i forgot some gaskets and other small things.
        Servicing
        Intercooler, oil sump, cooling system cleaning. Cylinder head cheking and base polishing ( 0,07 mm), valves shortened for 1 mm, cylinder head valve guide change (valves are in good condition, wear < 0,01 mm), valve/engine head V- form polishing, some cylinder head flowing.
        I think that details and services are necessary for full engine rebuild.
          • Sep 2008
          • 1041
          • Country: Italy
          Hello, I want change turbo with a new and original one from Audi, pistons rings, valves rings, so which other parts I must change and which are better?
          Thanks a lot!
          Bye
          Alessio
          Audi S2 Coupe ABY
          Audi S2 Avant
          Audi Cabriolet 2.0E
            • Sep 2008
            • 1041
            • Country: Italy
            Up!
            Thanks a lot friends!
            Bye
            Alessio
            Audi S2 Coupe ABY
            Audi S2 Avant
            Audi Cabriolet 2.0E
            • A80Avant
              • Sep 2005
              • 10873
              • Country: Greece
              alessio,
              buying an original RS2 turbo from audi is the signle most expensive buy you can make. The turbo alone will cost more than 1800euros and with the same amount of money since you are rebuilding the engine you can have a car with 400-450hp easy.
              Search in this forum and try and avoid mistakes that we did in the process of restoring and upgrading the engine
                • Sep 2008
                • 1041
                • Country: Italy
                Hello, I will pay the original Turbo about 1400 € from Audi by a friend, I know that is a high price, but I don't want modify too much my RS2, I want some invisible upgrade and not more.
                I'm undecided also if mount the Wagner Evo exhaust manifold and Evo Intercooler or leave the original parts because I have read somewhere here that Evo exhaust manifold can increase the turbo lag and Evo intercooler that is a bit bigger that the original one can also increase turbolag or not? I can't mount the reverse inlet manifold with his intercooler because is a too hard visible modify for me.
                Thanks a lot!
                Alessio
                Audi S2 Coupe ABY
                Audi S2 Avant
                Audi Cabriolet 2.0E
                • A80Avant
                  • Sep 2005
                  • 10873
                  • Country: Greece
                  as i already said, i use the 3071garrett, it spools almost as fast as the rs2 turbo, it fits with the all the rest of the rs2 parts and you cannot tell that you have it in there or there is just the original turbo, and you will be able to make almost 100+ more hp.
                  the wagner parts will make the lag worse only slightly,but with a BB turbo you wont tell the difference
                    For 1400 euros you'd be better buying the Turbo dynamics hybrid that DJones runs
                    You would be extremely silly to pay this price for the RS2 turbo when you could get better performance for the same price.
                      • Sep 2008
                      • 1041
                      • Country: Italy
                      Hello I know that with 1400 € I can buy a better turbo that the original RS2 one, but probably the problem is not the turbo but the seal valve stem, now the question is, which are the best parts for rebuild the engine? Original Audi parts or for example ARP head studs, Sputter rod bearings lower and upper? Other parts that I can change with better ones?
                      Thanks a lot!
                      Bye
                      Alessio
                      Audi S2 Coupe ABY
                      Audi S2 Avant
                      Audi Cabriolet 2.0E
                      • A80Avant
                        • Sep 2005
                        • 10873
                        • Country: Greece
                        search my friend! all these questions have been answered directly and indirectly.
                        my opinion is that if you want to get the best with the same money, go for aftermarket parts.
                        If you want to know which parts, email 034 motorsport or aelred and they will tell you.
