K Line Stuck Open
  • Tonks4x4
    • Nov 2005
    • 3062
    K Line Stuck Open
    Have tried many types of cables, including the rossteck one. Have tried many versions of VAG-COM on many different peoples laptop's and every time they get K line Stuck open...
    Will someone give me a clue what is happening, have you ever had this fault and how did you cure it?
    Audi Nut!!!
  • T2Andy
    • 1903
    Hi mate have you had a read on ROSS-TECH web site K LINE is mentioned quite alot
    hope you sought it
    • Tonks4x4
      • Nov 2005
      • 3062
      Still never got to the bottom of this so just thought I would bump it back to the top to see if anyone has a clue???
      Audi Nut!!!
      • prj
        • Mar 2010
        • 6308
        Aftermarket alarm or Radio giving 12V on K-Line probably.
        • Tonks4x4
          • Nov 2005
          • 3062
          Thanks Dimitri but I did check both of those avenues a long time ago.
          I will be converting to ABY in 2013 so will be swapping out the Engine loom and have a proper check of the dash loom while everything is out.
          It does my head in that I have never been able to read a fault code on this car and have managed to fix everything from manual testing of stuff
          Audi Nut!!!
          • prj
            • Mar 2010
            • 6308
            To read fault codes, disconnect Pin 55 and Pin 13 from the harness (ECU connector) and run them direct to your scan tool if K-Line is screwed.
            55 is K-Line and 13 is L-Line. You will need both.
              UrS C4, 200 20VT (3B) and S2/RS2 OBD1 Fault Code access port locations and info
              This might help:
              UrS C4, 200 20VT (3B) and S2/RS2 OBD1 Fault Code access port locations and info:
              • Tonks4x4
                • Nov 2005
                • 3062
                Lol, good idea the other 2x2 then only needs live and earth?
                That will be ok for engine but I have still got to sort it at some point as I would like to fit climate so would be good for scanning this also.
                Audi Nut!!!
                • prj
                  • Mar 2010
                  • 6308
                  Yea, it only needs live and earth in the black connector, you are right.
                  This is how I test all the ECU's on the bench before I ship them out.
