Hello All
I have recently joined this web site as i am now a very happy owner of standard 3b. The engine has 136k on it but has full service history and pulls very well indeed. Almost as quick as a standard s4 i had a few years ago.
However, as you do, the fever off wanting more power is kicking in once again. All good!!
First thing i did when i bought the car was to install a centre mount boost gauge to check if i was running standard boost or not. Bought one from auto gauge which i believe is not the best or most accurate make, however the boost consistantly peaks @ 0.75 bar when on full boost in 4th or 5th. As far as i read 0.8 bar is standard so not sure is the loss of 0.5 bar down to the cheap gauge or maybe a slight leak in the system somewhere? Not to worried as the car goes like it should with nothing untoward heard from under the bonnet when boosting.
Am i right in thinking someone remaps ecu's on here and this is called (homefries)?
If so how to i get in touch with this person?
How much will this cost?
What gains can i expect?
And am i right in saying that a 3 bar MAP sensor needs to get fitted to the ecu at the same time?
At the moment my car has a standard exhaust but will soon be getting a custom stainless made with the cats removed. I can get an mot sorted without so why not eh.
Look forward to hearing from you guys.
Regards
Gordon
Regards
Gordon
Next upgrade should be a modified inlet, RS2 or ABY airbox followed by a 3" exhaust and larger bore downpipe, should see 280+bhp and you'll be amazed at how strong the car goes over stock
