Now i have the RS2 setup what would i need to upgrade and what are the best parts to upgrade to? I want to maximise the potential for the RS2 turbo and then in the future get a garrett on there.
Internals Upgrade for RS2 Turbo!
get a 360 degree thrust bearing in the turbo if you haven't done so already... -
Cheapest are the SCAT style ones, Aronmatic has some for about ÂŁ350 a set. If you want the best quality then you're looking at nearly double that, Arrow, Carillo etc. Depends on the term 'best'
1994 ABY Coupe - Projekt AlpinweissComment
Yep Aelred fitted the manifold turbo etc. I was just planning on getting the rods changed to handle the RS2 turbo. What work is involved in getting it balanced and more importantly how much will it set me back (still saving for a house)3'' Longlife Exhaust, Koni Adjustables, H&R Springs, Full RS2 Setup with Mr Nugents RS2 Chips
(just need the RS2 Airbox)Comment
Probably going over old ground but whats involved in balancing the engine? I take it its 2-300 for the labour and the rest up to 1k is parts?3'' Longlife Exhaust, Koni Adjustables, H&R Springs, Full RS2 Setup with Mr Nugents RS2 Chips
