Fault Code
  • Paulm
    • Dec 2003
    • 489
    Fault Code
    2-1-2-1
    Closed Throttle Position Switch, F60
    - Open or Short to B+
    - Short to ground
    - Signal to ground
    F60 out of adjustment
    Throttle body sticking
    Throttle cable in need of adjustment
    Open circuit between F60 and J220
    J220 faulty
    Short circuit between J220 and ground
    Moisture in throttle body connector
    Idle speed erratic or outside specification
    Check & adjust F60
    Check F60 potentiometer and switches
    Adjust throttle cable
    Repair open or short ciruit
    Check electrical connections
    Repair short circuit
    Would this cause my car not to boost or is it just an idle problem. My car was idling erratically the other night. going from 500rpm to 1200rpm. the next day it was fine again.
    all info thanks to PaulN's S2 site
    cheers
    Paul
    S4 2.7 Twin Turbo, with a few mods
  • audiman
    • 4827
    This would cause the idle problem, the ECU wouldnt know that the throttle is shut.
    Tom C - www.rcmr.co.uk
    Audi UR Quattro
    Audi 100 C3 2.0 5 cyl 115ps
    Audi B5 RS4 645ps 911nm
      Agree with TomC here - keep reading the site and check the throttle pot and its built-in idle switch.
