Stock piston Question
  • Billman
    • 4129
    Hi, i am sure that the answer is somewhere in the forum but i need a quick answer.
    i had the following data for the pistons:
    If there are images in this attachment, they will not be displayed. Download the original attachment
    Sheet1
    A B C
    1 Specs: Stock ABY-ADU-3B Vasilis Motor
    2 Bore (mm) 81 81.5
    3 Stroke (mm) 86.4 95.5
    4 Number of Cylinders 5 5
    5 Block deck height (mm) 220 236
    6 Rod Length (mm) 144 158
    7 Wrist Pin Diameter (mm) 20 23
    8 Redline (rpm) 7500 7500
    9 Max Piston Speed (m/s) 20.448 27.05833
    10 Rod/Stroke Ratio 1.66667 1.65445
    11 Compression Height 32.8 30.25
    12 Ring Package (mm) 22.8 18.75
    13 Displacement (cc) 2226.09439 2491.02671
    14 Compressed HG (mm) 1.875 1.875
    15 Head Gasket Bore(mm) 82.5 82.5
    16 Bore Area (cm^2) 51.52996 52.16810
    17 Cylinder head cc's 44 44
    18 Head gasket cc's 9.66187 10.02303
    19 Piston Dish cc's 2 12.5
    20 Cylinder BDC cc's 445.21888 498.20534
    21 Total Volume BDC 500.88075 564.72837
    22 Total Volume TDC 55.66187 66.52303
    23 Compression Ratio 8.99863 8.48922
    Problem is the piston manufacturer says that the sample piston paul send has a total volume dish and pockets of 4.6 cc
    what is right?
    thanks in advance
    Go Holset or Go RS4
  • Billman
    • 4129
    come on people
    Go Holset or Go RS4
    • GazzaG60
      • 4133
      in general we leave this to the piston people billman.
      there may be some on here that can help.
      why dont you go for the available tried and tested pistons rather than having a cusrom one for you. it would be easier and less prone to issues.
      • lind4hl
        • Jul 2008
        • 2465
        yeah, what is so wrong with Wiseco´s / JE?
        • Billman
          • 4129
          The wrong thing is i dont like wiseco and JE doesnt make pistons for a stroker with the conrod i have. Appart from this no one has this info?
          I gave to the man this data i had from Justin Olson and it doesnt match the measurements they make! The possibilities are: They measured wrong piston or justin had an error in the file.
          regards
          Go Holset or Go RS4
          • G60Rallye
            • Dec 2006
            • 1321
            JE will make pistons to any spec that you want. Easiest way is to base it on there standard S2 pistons and then channge the aspects about you build which are different.
            This is the man you want to speak to:
            Nickolaus DiBlasi ndiblasi@jepistons.com
              regards
              JE and Wiseco have done stroker pistons for the 155m and 159mm rods
              If it's different they'll just change the spec.
              With so many strokers out there what makes yours special they can't make the pistons?
              • Flat on my back
                • Jan 2007
                • 2449
                And my 7A stroker on 144mm rods.
                Carlos.
                  Exactly 158mm should be easy to make, all that needs to be done is move the compression height and recalculate the dish cc
                  • A80Avant
                    • 10873
                    • Country: Greece
                    i think Billman has rods with 22mm pin rather than 20mm.One of the differences may be that.
                    • repo
                      • Dec 2004
                      • 893
                      44cc for head volume is a bit on a small side. I would say 47cc is more typical.
                      Although, there has been quite a fluctuation, from 45 to 49cc, but I think 44 is planed a lot.
                        I have 22mm wrist pins on my JE pistons as well it makes no odds to the piston company as they can build any spec
                        • A80Avant
                          • 10873
                          • Country: Greece
                          ok,so probably that was not the difference then!
                          • Billman
                            • 4129
                            people i simply want cp pistons, not je nor something else. i would be greatfull if someone can tell me the correct specs of the stock one.
                            Go Holset or Go RS4
                            • Billman
                              • 4129
                              @repo
                              thanks
                              the volume of the stock dish: 4.6cc in the piston is correct, the dish is 59.5mm dia x 1.44mm deep = 4.0cc + the valve pockets
                              Go Holset or Go RS4
