Which injectors?
  • Quattro Dan.
    • Dec 2005
    • 746
    Which injectors?
    Can anyone recommend the injectors i need for the following set up;
    injectors?
    GT3071
    rs2 exhaust manifold
    044 motor sport fuel pump
    scat rods
    bigger than standard intercooler
    AAN inlet manifold
    2.75 inch exhaust- no cats
    3 bar map sensor
    mechanical boost- no WGFV:mischeif:
    Also what sort of BHP should i get with this set up?
    Thanks in advance,
    Dan.
  • s2_bo
    • Oct 2005
    • 6067
    Siemens do some good ones at 660cc they are about £220 a set iirc, Audiman used to sell them.
    Cheers.
    bo
    91 S2 coupé - RIP
    98 S8 - Luxury barge
      probably just around 400 bhp, the 2.75 downpipe is may hurt you for backpressure at these bhp level.
      Any injector 440cc would do you. Bosch greens etc best ones would be the ones Bo's said above
      • AndyP
        • 6049
        http://cgi.ebay.com/ebaymotors/5-Bos...Q5fCarQ5fParts
        These are what I'm using in mine.
        • EBR
          • Jan 2009
          • 64
          • Country: Iceland
          I have 5 used Siemens Deka 580cc injectors. They are for sale if anyone is interested, you can pm me for more info.
          Eiríkur...
          Audi S4 20VT 11.453@121.62
          • david
            • Oct 2008
            • 1268
            Originally posted by AndyP
            are these just as good as Rs2 injectors?
            [SIGPIC][SIGPIC]/SIGPIC]92 3B pearl white=gone back home to Germany,probably in bits and pieces
            RS2 VOLCANO BLACK] soon to be broken to bits
              What so special about RS2 injectors...............
              Nothing
              • david
                • Oct 2008
                • 1268
                rs2 injectors
                nothing special,just a bench mark to gauge how good the injectors are
                  Your logic is flawed the RS2 injectors are not special there is nothing to benchmark against. The only thing special about them is they were designed for a specific cc output for the RS2 chipset.
                  When looking for injectors for the S2 you want a) multi point spray pattern over single pattern b) High impedance to work with the stock ECU c) Enough cc to flow for your BHP application.
                  • AndyP
                    • 6049
                    Depends what you mean by good? They are a Bosch injector like the RS2 so they are the same quality, but slightly higher flow capacity.
                    • david
                      • Oct 2008
                      • 1268
                      i think you hit the nail on the head. better flow,that's what i was looking for
                      • nip
                        • Apr 2006
                        • 1786
                        • Home: United Kingdom Current: Abu Dhabi
                        dan, i have some siemens 440cc injectors if ur interested
                        • trackslag
                          Account Disabled
                          • Sep 2009
                          • 171
                          have a play with this look at bottom of page
                            For the I5 engine it's even simpler injector cc equal bhp
                            • trackslag
                              Account Disabled
                              • Sep 2009
                              • 171
                              out of interest what size are standard ABY s2 injectoer anyone know?
