Hesitation!
    I've got vag com and a boost test kit Steve
    • T2Andy
      • 1903
      which 3 bar map censor didi you use
      • stevieyid
        • Apr 2005
        • 2251
        One for paul to answer as he put it in. John u have pm
        3'' Longlife Exhaust, Koni Adjustables, H&R Springs, Full RS2 Setup with Mr Nugents RS2 Chips (just need the RS2 Airbox)
          Sounds like a sall boost leak. You're running 97/8 too I hope, 95 can make these cars run like utter toss.
            Ah but knock sensors do indeed throw codes
            Originally posted by Jamo
            FYI knock sensors don't give codes
            Exqueeze me? Of course knock sensors throw codes:
            •2141 (Blink Fault Code), 00535 VAG1551/2 Fault Code Number
            Knock regulator #1
            Excessive knock, timing is being retarded by maximum amount,
            Symptom: Low boost on 20V, Fuel octane too low, Excessive Compression, excessive boost
            •2142 (Blink Fault Code), 00524 VAG1551/2 Fault Code Number
            Knock sensor #1 (G61)
            Open or short circuit, Defective sensor Check sensor and wiring
            Symptom: Timing retarded, High fuel consumption, power loss, Boost pressure not attained
            •2143 (Blink Fault Code),00536 VAG1551/2 Fault Code Number
            Knock sensor #2, (Cylinders 3, 4, 5)
            Excessive knock, timing is being retarded by maximum amount.
            Symptom: Fuel octane too low, Excessive Compression, excessive boost
            •2144 (Blink Fault Code), 00540 VAG1551/2 Fault Code Number
            Knock Sensor #2, (G66) (Cylinders 3, 4, 5)
            Reference: http://www.sjmautotechnik.com/troubl...g/20vcodes.htm
            and the Bentley manuals.
            • stevieyid
              • Apr 2005
              • 2251
              Yep running 97/98 RON and always have. Could do with my boost gauge so i can see what the boost is actually doing.
                I had a TIM one, they were cheap and it worked well, was lucky enough to pick up a VDO one secondhand for the same money. They're invaluable when diagnosing boost issues, if it flutters on WOT then you're more than likely losing boost.
                • stevieyid
                  • Apr 2005
                  • 2251
                  Yeah bought one from demon tweeks but does not work! So sending it back and getting another. Just takes time which is frustrating
                    Strange, I take it you've tried putting a line on it and sucking / blowing? SUre you've got the right line to tap off? (Sorry for the simple points but better to make sure )
                    • stevieyid
                      • Apr 2005
                      • 2251
                      Terrybullwon fitted it and just stuck at -5psi! Annoying as wheni really want it to see what happening i can use it
                      • stevieyid
                        • Apr 2005
                        • 2251
                        When out tongiht i opened the car up a few times. It takes off like a rocket if i use 3?4 throttle it seems at WOT it is when it hesitates and causes overboost protection. Any ideas?
                        • terrybullwon
                          • Mar 2006
                          • 8782
                          iirc newsh had that same problem, or am i making that up John?
                          Chef
                            Boost leak or maf wiring. We've been trying to get Steve over here for a leak test but we've both been busy on different days etc..
                            • stevieyid
                              • Apr 2005
                              • 2251
                              Ah ok. Dont suppose you are about tomorrow morning John are you? Hopefully get this sorted!
                                At work this week and away for the weekend, only possibility is tomorrow evening 7.00 ish.
