Mine was leaking at the clamp where it connects to the ECU so I just cut a half inch off the pipe (thats why I suggested you do this). You could just have split in the line somewhere, this will act as a kind of one way valve, opening under pressure and closing under vacuum.. You need to have a look at the back of the inlet manifold where all the small pipes connect and look for oil mist, a boost leak will bring a little bit of oil vapour with it thanks to the breather system
The line to theECU should connect to a hard plastic line on the bukhead.
This is pretty sure to be your screeching noise IMO.
The line to theECU should connect to a hard plastic line on the bukhead. This is pretty sure to be your screeching noise IMO.
Boost gauge was showing 1.3Bar dropping to 1 Bar steady to redline. I would think it could boost more but not sure what Paul has set it up to do.
