Coolant all over the driveway :(
    Well it seemed like my car was going really well apart from having to bail it out before getting in... Now it's got another kind of water prob leaking from sewhere below the power steering pump, can't see where though and thehose to the WMani was replaced when the Ps pump was done a few weeks back anyway the ur got me to Wales in fine style despite the rain
    so where can the water be leaking from?
  • T2Andy
    • 1903
    I think theres 2 hoses ,the one to the turbo failed on mine,then theres the larger one
    underneath.
      Check your after run pump, the hose from the stat to the coolant pipe.
      Check the jubilees are tight on the main hose from rad to block
      • A80Avant
        • Sep 2005
        • 10873
        • Country: Greece
        also check the plastic insert on the block(at the back) if it is corroded. The ones that GT500 was to be making in alloy
        • s2driveruk
          • 12696
          nightmare newsh, especially this time of the year hope you find the cause and glad the shark came to the rescue
          1992 3b S2 Coupe
          • mcandmar
            • Apr 2004
            • 5118
            Worst case its the water pump itself, i have that problem in the S4 at the moment, not looking forward to a timing belt change in this weather
            91CQ20v - Gone to a new home
            93UR-S4 - The Magic Carpet
            94S2Bus - The Emerald Express
              underneath.
              Newsh shouldn't have the turbo one as he's running a 3071r turbo so he'd have a banjo braided pipe from the water manifold as part of the kit
